garyDavey
Mar 03, 2022Initiate
GS108 v4 keeps cutting out
I have a switch linked to my broadband router via ethernet cable that runs from the router in the study, out the wall and up to a first floor office. Service provider for broadband is SKY. I have 5 d...
Mar 03, 2022Guru - Experienced User
Its only the devices that are connected to the switch that are having issues?
Have you taken the switch in by the router and direct connected it with a new/high quality ethernet cable? I've seen sketchy cables cause issues before.
Also, the gs108 is a simple unmanaged switch. There isn't any processing done with the data. Usually they either work or not. there isn't really any in-between when they're going bad. So I'd start with checking connections.
garyDavey
Mar 04, 2022Initiate
So I've had the sky router replaced. If i plug the ethernet cable that runs direct from the router to my netgear switch directly into my dell laptop it sets up a connection automatically, no problems. If I plug the same ethernet cable into the netgear switch and then run an ethernet cable from the switch to my pc (kenable Cat6A SSTP Snagless Shielded RJ45 Network Ethernet 10GIG Cable 1m BLACK purchased october 2021) the pc does not recognise the connection and comes up with various errors; Starts off saying "identifying network, no internet". That then changes to "unidentified network, no internet". If I run network diagnostics on it it says "network doesn't have a valid ip configuration".
The switch was bought on 10th June 2021 and I purposely went for the most up-to-date unmanaged switch as I didn't want the hassle of having to manage it (I'm no networking expert). The cables I use are all kenable cat6a which were purchased at the same time and the ethernet connection to the router was installed by sky at the same time as well from the downstairs study to the upstairs office and as I've proved that connection works fine when connected direct to the laptop.
Thoughts?
