alienz
Sep 27, 2016Guide
GS108E-300NAS vs GS108T-200NAS
So I'm looking to purchase an 8 port web managed switch that supports vlans and port mirroring, no PoE needed. Overall these two switches seem to be pretty similar. GS108Tv2 - GS108T-200NAS GS1...
- Apr 11, 2017
As a summary, we learned that:
Similarities between the GS108Tv2 and GS108Ev3 switches:
a. Both switches will provide standard 802.1Q VLAN management per port, based on Untagged or Tagged modes, with or without PVID - which correspond to basic Access or Trunk port modes, with or without Native VLAN in other terminologies.
b. Both switches will provide standard Port Mirroring, ingress or egress or both, with multiple source ports and one destination port. When set in Mirroring mode, the destination port cannot work normally, i.e receive and send normal traffic - true for both switches.
Differences between the GS108Tv2 and GS108Ev3 switches:
a. The GS108Ev3 offers HTTP web interface and management, hence no encryption for restricting management access. On the other hand, the GS108Tv2 offers HTTPS web interface and management, which will be better fit for application outside of your firewall.
b. The GS108Tv2 can be powered by upstream PoE switch via its port 1 while the GS108Ev3 does not support this.
c. The GS108Tv2 provide more advance features such as Access Control for security (ACLs) and Differentiated Services (QoS) for packet prioritization will be done at Layer 2/ Layer 3/ Layer 4.
Credits to LaurentMa :)
Cheers,
DaneA
NETGEAR Community Team
alienz
Sep 27, 2016Guide
Thanks much, this was a very detailed and helpful response.
One last question, when you say the destination port in mirroring mode cannot work normally, I assume you mean the host connected to that port would not be able to function properly?
My plan is to stand up a Snort box and connect the sniffing interface to the mirror/SPAN port, I'm assuming this would work with either switch.
LaurentMa
Sep 27, 2016NETGEAR Expert
Hi alienz
This is correct, the sniffer can be connected to the mirroring (destination) port on either switch, per design.
If this was a standard host instead, no "normal" Ethernet traffic could be received on that port, given the fact only mirrored ingress or egress traffic is sent to that port.
Good luck with the Snort box project, we hope the NETGEAR switch will be a perfect fit!
