alienz
Sep 27, 2016Guide
GS108E-300NAS vs GS108T-200NAS
So I'm looking to purchase an 8 port web managed switch that supports vlans and port mirroring, no PoE needed. Overall these two switches seem to be pretty similar. GS108Tv2 - GS108T-200NAS GS1...
- Apr 11, 2017
As a summary, we learned that:
Similarities between the GS108Tv2 and GS108Ev3 switches:
a. Both switches will provide standard 802.1Q VLAN management per port, based on Untagged or Tagged modes, with or without PVID - which correspond to basic Access or Trunk port modes, with or without Native VLAN in other terminologies.
b. Both switches will provide standard Port Mirroring, ingress or egress or both, with multiple source ports and one destination port. When set in Mirroring mode, the destination port cannot work normally, i.e receive and send normal traffic - true for both switches.
Differences between the GS108Tv2 and GS108Ev3 switches:
a. The GS108Ev3 offers HTTP web interface and management, hence no encryption for restricting management access. On the other hand, the GS108Tv2 offers HTTPS web interface and management, which will be better fit for application outside of your firewall.
b. The GS108Tv2 can be powered by upstream PoE switch via its port 1 while the GS108Ev3 does not support this.
c. The GS108Tv2 provide more advance features such as Access Control for security (ACLs) and Differentiated Services (QoS) for packet prioritization will be done at Layer 2/ Layer 3/ Layer 4.
Credits to LaurentMa :)
Cheers,
DaneA
NETGEAR Community Team
carrots
Nov 17, 2016Aspirant
Hello! I am also interested in these switches.
I saw you mentioned there was extra security features on the gs108t.
I already read elsewhere that gs108e has basically no way to restrict management of the switch at all. And it's done in plaintext.
I am going to put a switch outside my firewall and I want to restrict management access entirely.
Will gs108t work for me?
LaurentMa
Nov 18, 2016NETGEAR Expert
Hi carrots,
Yes, GS108Tv2 will work better than GS108E for you I'm sure.
GS108E offers HTTP web interface and management, hence no encryption for restricting management access.
GS108Tv2 offers HTTPS web interface and management, which will be better fit for your application outside of your firewall.
I hope this helps,
