alienz
Sep 27, 2016Guide
GS108E-300NAS vs GS108T-200NAS
So I'm looking to purchase an 8 port web managed switch that supports vlans and port mirroring, no PoE needed. Overall these two switches seem to be pretty similar. GS108Tv2 - GS108T-200NAS GS1...
- Apr 11, 2017
As a summary, we learned that:
Similarities between the GS108Tv2 and GS108Ev3 switches:
a. Both switches will provide standard 802.1Q VLAN management per port, based on Untagged or Tagged modes, with or without PVID - which correspond to basic Access or Trunk port modes, with or without Native VLAN in other terminologies.
b. Both switches will provide standard Port Mirroring, ingress or egress or both, with multiple source ports and one destination port. When set in Mirroring mode, the destination port cannot work normally, i.e receive and send normal traffic - true for both switches.
Differences between the GS108Tv2 and GS108Ev3 switches:
a. The GS108Ev3 offers HTTP web interface and management, hence no encryption for restricting management access. On the other hand, the GS108Tv2 offers HTTPS web interface and management, which will be better fit for application outside of your firewall.
b. The GS108Tv2 can be powered by upstream PoE switch via its port 1 while the GS108Ev3 does not support this.
c. The GS108Tv2 provide more advance features such as Access Control for security (ACLs) and Differentiated Services (QoS) for packet prioritization will be done at Layer 2/ Layer 3/ Layer 4.
Credits to LaurentMa :)
Cheers,
DaneA
NETGEAR Community Team
d_rick
Dec 05, 2016Tutor
LaurentMa wrote:Hi alienz
Welcome to the community!
Yes, given your requirements you may be better off going with GS108Ev3 Web Managed (Plus) switch.
Both GS108Tv2 Smart Managed and GS108Ev3 Web Managed (Plus) will provide standard 802.1Q VLAN management per port, based on Untagged or Tagged modes, with or without PVID - which correspond to basic Access or Trunk port modes, with or without Native VLAN in other terminologies.
Yes a standard browser from Linux environment should let you access both switch web interfaces (GUI). You will find supported browser versions in each switch datasheet: GS108Ev3 and GS108Tv2. Should you eventually need to emulate those browsers or use a special compatibility mode.
Yes GS108Tv2 will provide more advanced features (Security; QoS), and can be powered by PoE instead of using local power adapter.
Let us know if you have any questions, and please share your impressions when you get your new 8-port switch!
Hi Laurent,
I'm in the process of needing another smart switch to pair with my GS716tv2 so that i can fully implement VLAN's. I currently have a GS108 v1, and apparently it does not support them? Between these two models it appears that you are stating they have the same VLAN functionality with no differences, is that correct?
Can you also provide any other details on your other comment:
"Yes GS108Tv2 will provide more advanced features (Security; QoS), and can be powered by PoE instead of using local power adapter."
LaurentMa
Dec 05, 2016NETGEAR Expert
Hi d_rick
Are you sure it's GS108v1? GS108 is Unmanaged Switch hence no real support for 802.1Q VLANs.
If that's the case, I would advise you select GS108Tv2 instead: Product Page and Datasheet.
GS108Tv2 is a Smart Managed switch, consistent with your GS716Tv2 for VLAN configuration.
If you have GS108Tv1 instead (previous version of GS108T Smart Managed switch),no problem, it will support VLANs just fine with your GS716Tv2 as well.
My last comment about GS108Tv2 was about differences with Web Managed (Plus) GS108Ev3 switch:
- GS108Tv2 can be powered by upstream PoE switch via its port 1
- As a Smart Managed switch, Access Control for security (ACLs) and Differentiated Services (QoS) for packet prioritization will be done at Layer 2/ Layer 3/ Layer 4
I hope this helps!
