PleaseWorkNow
Aug 15, 2019Aspirant
GS108Ev3 DHCP fails for VLAN
We bought this GS1088Ev3 to route multicast to dedicated port for IPTV (T-We from Telenor) as this switch are advertised with the possibility to choose which VLAN to enable IGMP Snooping. Sadly we a...
- Aug 15, 2019
If the GS105 essentially worked on the LAN - except that the ICMP multicast came up on all ports - all you have to configure is the VLAN ID 1 (and PVID 1) on all ports, [U]ntagged, and have the IGMP Snooping enabled for VLAN ID 1. Keep the validation and block unknown to disabled.
Behind the router, you won't have to deal with the VLAN ID 854 - this is used only on the WAN/Internet/ISP side of your router.
This is also the reason the IPTV STB does not receive even an IP address - it's "listening" to the isolated VLAN 854.
PleaseWorkNow
Thanks for your reply.
GS108Ev3 replaced GS105 in a working setup — no other changes. Yes IPTV are over LAN, hence the upgrade to try suppress chatter.
Below are my non functioning settings. Port1 are the uplink with IPTV on Port8
Are there a way to flush tables on GS1080Ev3 other than reboot?
schumaku
Aug 15, 2019Guru - Experienced User
- Jun 23, 2018Retired_Member
