Retired_Member
Jun 23, 2018gs108ev3 eats DHCP traffic
Hi,
I need to be able to separate IPTV and lan, and configure them to different ports as described below.
Problem: My ISP delivers IPTV on vlan46, and untagged traffic on the same cable.
At present, using the latest firmware, the above is not possible (or please tell me how to configure it).
If I don't configure the switch at all, connects the "uplink" from ISP to port 1, USG to port 2, and IPTV-box to port 3, it kind of works. Though the network is then bashed/stressed with multicast packages that should only reach the IPTV-box.
If I configure the switch as follows below, I only get IPTV, the USG does not receive the external DHCP address it needs;
P1: Uplink from ISP
P2: To USG Wan1 (Ubiquiti Security Gateway)
P3: To Arris IPTV
Configuration:
vlan1:
p: 1, 2, 4, 5, 6, 7, 8
vlan46:
p: 1, 3
Port Membership:
vlan1:
p: 1(T), 2(U), 3(-), 4-8(U)
vlan46:
p: 1(T), 2(-), 3(U), 4-8(-)
PVIDs:
p: 1-2(1), 3(46), 4-8(1)
Doing this exact thing using a Ubuquiti switch works like a charm, which to me indicates the gs108ev3's firmware is causing this problem. Netgear switches are quite new and buying new ones are not an option at this point.
Please confirm this problem or please tell me how to configure the switch.
Thanks
- Retired_MemberJul 08, 2018
Hi,
I think you may have misunderstood. It is the Netgear switch that cannot handle the incoming traffic. It is the first device my incoming traffic passes, ie before the USG (firewall) and fails to separate the iptv vlan and the untagged traffic when configured to do so. On the port where only untagged traffic should lead to the USG, the iptv multicast traffic is also delivered, which it should not.
But since I have the setup I need using Ubiquiti equipment, I don't really see the point in continuing this thread. I thought I marked it as solved?
- Retired_Member
LOL. Netgear chat "support" kindly indicated this cannot be done. WoW. Even after I told them this has been done with Ubiquiti's switch. By myself. Minutes ago.
Sorry, but from now on Netgear is just a joke to me. The hardware is great (for what I can tell), that I will still agree with, but if the firmware don't match it - what a waste. I will give away/sell/return all my Netgear stuff except for a few unconfigured switches, as those have proven useful at times. More complex(?!) setups (as this easy one) are obviously not well suited for at least the Netgear GS108ev3.
Guess my new favourite brand?
- DaneANETGEAR Employee Retired
Hi Retired_Member,
Welcome to the community! :)
Not sure if you already came across with the article below. If ever you still have the GS108Ev3, kindly access the article and check if it helps:
Default IGMP settings may affect multicast streams on NETGEAR Web Managed Plus Switches
DaneA
NETGEAR Community Team- Retired_Member
Hi,
thanks for the suggestion. Though in my case IGMP and IPTV was not the issue, but the switch not letting external DHCP traffic/negotiation through it. Perfectly normal according to Netgear support, but other brands do this and even acknowledges they should do so.
Retired_Member,
Just following up on this. Here are my follow-up questions below:
a. What model of Ubiquiti Security Gateway are you using?
b. If you will remove the Ubiquiti Security Gateway from the setup, does everything work?
c. Is the Ubiquiti Security Gateway configured to reach the ISP gateway and has the correct VLAN tag set on it?
DaneA
- Retired_Member
Hi,
- Apr 12, 2023Retired_Member
