attilay2k's avatar
attilay2k
GS108Ev3 VLAN Setup
Hi all, i've bought GS108Ev3 Managed switch in order to create a segregation for my devices, by type. My intention was to separate PCs from Phones and from Cameras. My firmware version is 2.00.12 b...
  • schumaku's avatar
    Jun 06, 2019
    Hi,
    Each 802.1q VLAN is a L2 network, like using different switches or wireless AP for multiple LANs, creating a unique broadcast domain. this is what you can configure on the Smart Managed Plus switches. One more point: The Smart Managed Plus management interface is floating and connecting to all VLANs (except of e.g. the XS724EM where a management VLAN can be defined) so the switch can be discovered, and might (and will) pick up IP addresses from any VLAN.
    Before you start looking for a bigger model supporting L2/L3 including IP routing: This will probably not achieve what you expect. On one hand, you won't win much security, on the other hand, you might even loose functionality.
    For a proper set-up of multiple VLANs with some security segregation, you need a router allowing the management of multiple subnets and security zones, either with VLAN or at east with dedicated ports.
    -Kurt
    PS. A moderator is kindly asked to move this thread to the appropriate Business Solutions -> Switches -> Smart / Plus / Click Switches
ProSupport for Business
