Hubert_Tu's avatar
Hubert_Tu
Vlan setup on GS108EV3
Hi,
I bought a GS108E and want to set Vlan, and I found something might be wrong. Sometimes I found PC could not connect to internet when TV box is turnning on, and I have to reboot GS108E to make PC connecting to internet correctly.
Please help to check the settings below are all correct or not, thanks.
Port 1: TV box, need to connect to internet via port 8
Port 2: Webcam, need to connect to internet via port 8
Port 3 ~ 7: PCs, need to connect to internet via port 8
Port 8: Wan port, from ineternet via router.
Vlan 1: port 1~8 as default, all are untagging.
Vlan 2: port 1, port 8, both are untagging.
Vlan 3: port 2, port 8, both are untagging.
Vlan 4: port 3~8, all are untagging.
Port 1: PVID is 2
Port 2: PVID is 3
Port 3~7: PVID is 4
Port 8: PVID is 1
  • JohnC_V's avatar
    JohnC_V
    Oct 24, 2017
    Hubert_Tu,
    I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Hubert_Tu,
    Welcome to our community!
    As per checking in here that the PVIDs are on a different VLAN. May I know why is it the that PVIDs are on a different VLAN? Is there any DHCP server that provides IP to those VLAN? You may also take advantage of the free 90 days support with our support team. Please create a chat / case online on NETGEAR support and please let them know what you wanted to achieve here.
  • JohnC_V's avatar
    JohnC_V
    Hubert_Tu,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
    • Hubert_Tu's avatar
      Hubert_Tu
      Hi, Sir,
      I've gotten the answer from chat/case support. I have kept my configuration on GS108E for more than 3 days and there is no other problems.
      Thanks for your help!
      • JohnC_V's avatar
        JohnC_V
        Hubert_Tu,
ProSupport for Business
