Hubert_Tu's avatar
Hubert_Tu
Vlan setup on GS108EV3
Hi,   I bought a GS108E and want to set Vlan, and I found something might be wrong. Sometimes I found PC could not connect to internet when TV box is turnning on, and I have to reboot GS108E to mak...
  • JohnC_V's avatar
    JohnC_V
    Oct 24, 2017
    Hubert_Tu,
    I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
