boward57
May 30, 2023Aspirant
GS108PEV3 IP address still default on DHCP Network
This switch connects to a JGS516PE which in turn is connected to the DHCP server in the form of Wi-Fi router provided by the ISP. The 16 port switch gets a proper IP address from the DHCP server but ...
MJHG23
Sep 19, 2023Aspirant
Resurrecting this post, how did you get this to work exactly? Have the same issue and banging my head against the wall 2 weeks now.
I've got a Google nest wifi mesh router directly connected to the ISP modem distributing DHCP. Next connected is a GS305ep switch from Netgear and picks up the IP in the same subnet as the Google Wi-Fi correctly, followed by downstreamed GS108PEv3 however all of a sudden after a power outage, can't get the GS108 for the life of us to get an IP attached per DHCP no matter what. This used to work but I have a feeling that it's stuck on the. 0.239 IP Network. I have assigned its MAC address with a DHCP reservation through the Google nest to no avail. Have done a hard reset and clean reset but it will not provide it a connection IP. At a loss and stand still as to what could be the issue.
One ironic item to mention is if I were to connect one of the Google points to that GS108 router downstream at the end, that one picks up it's IP address and meshes with the system perfectly, but all the other direct connected devices, including the switch itself, do not get allocated an IP address...
schumaku
Sep 19, 2023Guru - Experienced User
MJHG23 wrote:
I've got a Google nest wifi mesh router directly connected to the ISP modem distributing DHCP. Next connected is a GS305ep switch from Netgear and picks up the IP in the same subnet as the Google Wi-Fi correctly, followed by downstreamed GS108PEv3 however all of a sudden after a power outage, can't get the GS108 for the life of us to get an IP attached per DHCP no matter what. This used to work but I have a feeling that it's stuck on the. 0.239 IP Network. I have assigned its MAC address with a DHCP reservation through the Google nest to no avail. .
The point is the very basic DHCP client on all uC equipped Plus switches. After power-up (following the power failure), these switches are becoming active very quick, but the DHCP request does time-out much to fast. Check the switch in question has DHCP active. Now cold start (power off-on) this switch, and you will very likely see the DHCP succeed, and get the IP config assigned as per the DHCP MAC reservation on your Google Wi-Fi.
Your Google Mesh system does not boot comparably fast like the Plus switches, and it has a better DHCP client on board, re-trying longer than the Plus switches. The point is that the switches are becoming active with the defined configuration, regardless of the DHCP assigned admin address, and never retry the DHCP request.
The OP applied a work-around on the Plus switch, and put a static IP config in place.
