mcsweeney
Jul 07, 2019Aspirant
GS108PEv3 PoE Mode A capability ?
Hi, we are contemplating buying some GS108PEv3 switches, or the bigger-port equivalents for our building. We have a number of IP security cameras which are PoE powered. However, many of these are using older Cat5e/6 wiring which is only wired for 2 data pairs, no spare pairs. As a result we would require that the switches support Mode-A PoE, ie. power over the two data pairs, rather than relying on spare pairs.
Can you confirm that these switches will work with 4-wire RJ45 wirings ?
Thanks.
I just got a feedback from the higher tier of NETGEAR Support. The NETGEAR 802.3af/at PoE switches supports ALT-A mode (Ethernet 1,2,3,6 pair) and will deliver power to PD’s (power devices), that should cover 10/100Mbps devices like the the IP camera you have mentioned. If only using 2 pair cable, the you must make sure that the PD supports ALT-A and must use CAT5 for 10/100M, or CAT5E for 1000M (4pair).
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Let me inquire this to the higher tier of NETGEAR Support. I'll post here once I got a feedback.
DaneANETGEAR Community Team
Please not that a connection with just to pairs can only reach a max link rate of Fast Ethernet (100 Mbit/s). With Gigabit Ethernet, there are no spare pairs, all foir pairs (eight strands) are used for communication.
We have done some tests in the past with various Netgear PoO and PoE+ switches (like GS510TP, GC110PP, GC510PP, ...) and found e.g. an Arlo Q Plus connected by a patch cable with just the (right) two pairs is powered and an Ethernet link is established to working camera conditions.
In my opinion, a standards compliant PoE(+) switch can negotiate power requirements and operate both Mode A and Mode B PDs.
- mcsweeneyAspirant
Hi, thanks for the reply. I was aware with this configuration I would only get 100MBPS but I think that's ample for our cameras.
I suppose the next question is, is this switch (GS108PEv3) PoE+ (both 803.11at + af compliant), as it is simply described as PoE.
I'd imagine this configuration I am suggesting, though technically compliant with the standard may be rarely enough used to have had its support dropped.
Any standards compliant 802.3af or 802.3at PSE (endspan [integrated with the PoE switch] or mid-span [PoE injector]) must be able to detect, power and work PDs with alternative A or alternative B versions. The power alternate to be used is defined by 25kOhm resistors on the PD side.
PS. The IEEE standards talk of alternative A and B, not mode A and B.
Just a follow-up question, what specific brand and model of device/s that you will connect directly to the GS108PEv3 switch to power it up?
- mcsweeneyAspirantHi, this would be representative of devices we intend to power :
https://hviewsmart.com/collections/wifi-poe-cameras-nvrs/products/h-view-poe-ip-camera-4mp-h-265-cctv-camera-poe-cameras-outdoor-2-8-8mm-motorized-lens-auto-focus-onvif-nas-ip-cameras- DaneANETGEAR Employee Retired
Regards,DaneA
- mcsweeneyAspirant
Hi, thanks for help. GS108PEv3 was purchased and does indeed work with both Cat5 4-wire Mode-A cabling, and of course Cat6 8-wire Mode-B.
THanks.
Thank you for the confirmation and the feedback, very useful for future readers!
