gil_h
Oct 11, 2022Tutor
Gs108T erros
My gs108t managed switch suddenly started to reset it self. Power led turns from green to orange constantly and the switch resets it self. The switch worked perfectly find previous to that. I have t...
gil_h
Oct 11, 2022Tutor
Same issue if nothing connected.
After a factory reset it hold a little bit longer (an hour or so) and then this error resume.
About the warranty, netgear said to me that they are not going to accept the lifetime warranty on the router because the country I live in... not legal, not very acceptable. They has no problem selling me those switches.
Oct 11, 2022Guru - Experienced User
what region are you in?
do you have a case Number? maybe a mod can help with it.
- gil_hOct 12, 2022TutorI'm from Israel.
Have several case numbers, last one from last week is 46558154.
Previous case number, when they told me I can't use the warranty is 4519838.
Thank you for your help. đ
