ande1416
Apr 25, 2020Follower
GS108T Invalid Access Token
Hello - When I access the web management for my switch, I get an invalid token error and cannot login. I have to disconnect it from the internet to access it via local management. This is ...
Dusty007
Jul 02, 2022Aspirant
Invalid Access Token stopped after running SmartControlCenter V1.1.3.4, discovering the device, and logging in from its Web Browser Access button. It did not work using Switch Discovery Tool V1.2.103.exe.
- schumakuJul 02, 2022Guru - Experienced User
There exist three different versions of these GS108T switch models, GS108Tv1, GS108Tv2 and GS108Tv3. What is exactly on the product label attached?
The v1 is about 15 years old, the v2 is more than 12 years old since the product release. This would reflect an extremely shelf time for what you describe to be a new switch. Neither the Smartwizard Utility nor the Smart Control Center are required on the newer hardware models for many moons.
Does the utility show a current installed firmware version?
