connorsapps
Oct 23, 2022Tutor
LAN Invalid MAC address.
When going to add a static ip under Advanced > Setup > LAN Setup. Going to add an address reservation don't work for any of my devices. When clicking add I get the message:
| Invalid MAC address. 80E6500BC742 |
for MAC address 80:E6:50:0B:C7:42, ip 192.168.1.32.
| Hardware Version | R8000P |
| Firmware Version | V1.4.4.94_1.3.56 |
| GUI Language Version | V1.4.3.86_2.1.46.1 |
| LAN Port | |
| MAC Address | 3C:37:86:F2:C2:5E |
| IP Address | 192.168.1.1 |
| DHCP | On |
This is a known issue and has been passed on to NG.
Find downloads here;
https://www.netgear.com/support/product/R8000P.aspx#download
Note: this was previously working before router software update.
After the update, did you try a factory reset?
If that doesn't help, you can always downgrade back to the older version of firmware.
- I’ve tried a factory reset. I’ve looked into rolling back the version a bit but is there a way to find older downloads?
you could downgrade the FW, add your reservations, then upgrade again and the settings will stay tho it’s a hassle! 😇
that’s what I’ve been doing with the latest FW and the NTP // Invalid Mac problems! 🙂
the 6to4 was solved with using DHCP server option! 😀
- Thanks so much for the quick help. I was getting close to throwing my router and it’s 90s interface into a pond.
- obnaesInitiate
I would use the word "solution" carefully. LOL It did not work for me., I am at the latest firmware and this feature worked then but the upgrade, not only broke the feature, but deleted all of my existing address reservations #doublefail
I recommend using last working version of FW.
This is a known issue and NG IS working on a solution.
