MyNetworkIsBrok
May 22, 2025Tutor
GS108T not responding and all LED are turned on
Hello.
I have a Netgear GS108T that worked great for many years. But starting today, it's no more the case.
On the network side, no more packet goes through it. And I cannot access its web interface.
On the physical side: All the LED of its front panel are turned on. The power led is orange and the 2 LED of each Ethernet interfaces are green.
When I remove the power cable, wait 30 secondes and plug the power cable again: All the LED turn on immediately.
I searched in the manual but cannot found the meaning all the LED turned on.
Do you think it is broken ?
Ok, I have 2 switch Netgear GS108T. After connected the not responding switch to the power supply of the other switch, it start correctly.
So, it's the power supply of the switch that cause the problem. Confirmed with a voltmeter: The suspect power supply only deliver 7 volts instead of 12.
Do you know if it's easy to buy only a compatible power supply ?
Should be easy, unless you explicitly want "original" Netgear OEM, head to ebay.com and search for "netgear gs108t power supply" - US prices are in the range from about 9..15 USD.
And, sometimes, the power LED blink. But the number of blink seems to be random and I see no repetitive paterne in it.
