jacobhuerta
Jul 16, 2019Tutor
GS108Tv2 Configuring Port Mirroring disconnects switch from network
Product: Netgear ProSafe 8-port Gigabit Smart Switch GS108Tv2 OS: Windows 10 Whenever a user is attempting to configure port mirroring in the web access panel, after applying changes the web pag...
- Jul 16, 2019
schumaku wrote:Sounds like something Netgear should be able to reproduce. Afraid, no such spare switch at hand here.
Since a bit of time has passed I decided jump on schumaku's idea and went on the hunt for another GS108Tv2 to see if I could replicate the issue myself. I did find one, swapped it out with the current one in my network and configured it exactly as mentioned before. It seems to work fine and we haven't had any problems even after rebooting, unplugging different devices and messing around, in general, trying to break it. The solution might be just getting a new switch if this problem is encountered by anyone else. The switch we got is exactly the same only newer and with the most recent firmware update. It's hard to say what the actual problem was, everything was hooked up and configured exactly the same only with a different GS108Tv2 switch so it might be just a bad switch.
So far its pretty promising, I will mark this as a solution though its not clear what the problem actually was. It would be nice if someone from Netgear can comment whether or not this was a problem that existed in an older version of this switch.
Attached is a screenshot of our port mirroring settings on the web interface and smart control center.
jacobhuerta
Jul 16, 2019Tutor
This was a lapse in my description, we are using port 1 to mirror packets from port 2 through 7 and using one 8 manage the switch. It seems possible since we've accomplished this before. We are using this because our org doesn't allow use to buy hubs anymore so we have 6 boards connected to the switch, one port is used to manage while another is used to listen. So yes we are sure, though if anyone has another idea we are open to it as well.
schumaku
Jul 16, 2019Guru - Experienced User
- jacobhuertaJul 16, 2019Tutor
