jacobhuerta's avatar
Jul 16, 2019
GS108Tv2 Configuring Port Mirroring disconnects switch from network
Product: Netgear ProSafe 8-port Gigabit Smart Switch GS108Tv2 OS: Windows 10   Whenever a user is attempting to configure port mirroring in the web access panel, after applying changes the web pag...
  • jacobhuerta's avatar
    jacobhuerta
    Jul 16, 2019
    schumaku wrote:
    Sounds like something Netgear should be able to reproduce. Afraid, no such spare switch at hand here.
    Since a bit of time has passed I decided jump on schumaku's idea and went on the hunt for another GS108Tv2 to see if I could replicate the issue myself. I did find one, swapped it out with the current one in my network and configured it exactly as mentioned before. It seems to work fine and we haven't had any problems even after rebooting, unplugging different devices and messing around, in general, trying to break it. The solution might be just getting a new switch if this problem is encountered by anyone else. The switch we got is exactly the same only newer and with the most recent firmware update. It's hard to say what the actual problem was, everything was hooked up and configured exactly the same only with a different GS108Tv2 switch so it might be just a bad switch.
    So far its pretty promising, I will mark this as a solution though its not clear what the problem actually was. It would be nice if someone from Netgear can comment whether or not this was a problem that existed in an older version of this switch.
    Attached is a screenshot of our port mirroring settings on the web interface and smart control center.
ProSupport for Business
