pwood999
Mar 25, 2020Aspirant
GS108Tv2 flooding multicast at regular intervals
Hi All, Just bought a 2nd hand GS108Tv2. Configured management IP & upgraded to latest firmware. Then configured IGMP Snooping global plus VLAN's 1 & 3. All ports are members of both 1 & 3 untagg...
- Mar 26, 2020
I think I resolved the issue. GS108T requires IGMP configured as above, PLUS the "Block Unknown Multicast" to be enabled. Now the IGMP seems to work properly for Video.
Not sure yet if anything else using multicast is impacted.
Hope this helps others.
pwood999
Adding to my earlier post. Attached is switch config in case any guru spots the problem.
File is PDF format becasue I cannot upload the txt version.
- pwood999Mar 26, 2020Aspirant
