ljkrush
Jan 25, 2020Aspirant
GS108Tv2 Link-up Speed Issue
I have my GS108Tv2 router connected to a Synology 1815 NAS, a couple PCs and of course an internet connection through a D-Link GB Switch DGS-10240. All direct connections through the router work v...
- Jan 26, 2020
The GS108Tv2 is a GbE switch, not a router - thats however not the issue here. Unless the port used for the uplink on the GS108Tv2 is configured to run on 100 Mbit/s only, the best guess is that the cabling used between the GS108Tv2 and the unmanaged DGS-10240 is not wired correct so that the switches can negotiate any other speed than 10 or 100 Mbit/s. The 10..11 Mb/s throughput does clearly indicate a Fast Ethernet link only. There is either a cable with just two pairs (four strands) in the link, or the pairs are not correct crimped/pressed so the GbE link - requiring four pairs (eight strands) - so the switches can negotiate to GbE speeds.
schumaku
Jan 26, 2020Guru - Experienced User
