ShawnSpencer
Aug 24, 2022Aspirant
GS108Tv3 8-Port Gigabit Smart Managed Pro Switch - dropdown in connectivity speed when using zoom
Hi I have a GS108Tv3 8-Port Gigabit Smart Managed Pro Switch When I use zoom the Switch drops down on connectivity speed form 1 GB to 100 mb. The Switch is connected via LAN to the Co...
CrimpOn
Aug 24, 2022Guru - Experienced User
It would help if you describe the network in more detail:
- Which components are involved?
- Where is the switch placed?
- What device is being used for Zoom and how is it connected?
- How is the change in switch speed detected? (LED on switch?)
- ShawnSpencerAug 24, 2022Aspirant
GS108Tv3
Logitech StreamCam
Attached to the iMac with 3 m LAN Cable Kat. 6a
iMac, OSX 10.14.6
LAN Cable Kat. 6a
LED on Switch
Web-Interface of the Switch on the Browser - there one sees the speed of every of the 8 ports
Speed test
Thank you for help
- CrimpOnAug 24, 2022Guru - Experienced User
This is totally a local network issue? (No internet connection? No router? No WiFi?)
Both the iMac and camera are connected to this switch?
This is the camera: https://www.logitech.com/en-us/products/webcams/streamcam.html
There is an internet connection via Fiber Box 10GB Router
No WiFi is used
The Camera is connected to the iMac and the iMac is connected to the Switch
Yes
