muRe's avatar
muRe
GS108TV3 getting automatically disconnected
I have bought two netgear GS108TV3 Switch. First some of LAG changes to Admin-Disable, and I manually change them. But then both of them losing connection within few hours. One of them works well with factory reset mode, but the other stops working even in factory reset mode. I have configured nothing but VLAN and even the trunk port doesn't get connection and only possible way to enter GUI is by changing the PC ip address according to standard gateway. But first few hours everything works just fine also GUI access. My LAG configuration is
Admin : Enable
Autonegotiation: Enable
Speed: Auto
Link Trap: Disable
Any help will be greatly appreciated
  • Operating a LAG wit two or more ports for the switch-switch trunk, and/or operating more LAG for connecting additional devices?
    Tell us more about the intended LAG config please.
  • I have a follow-up question. How do I edit or delete a post? I made a typo and don't know how to edit it. My 2nd sentence is making no sense. What I meant is, after the installation ports are getting disconnected one by one, and it shows in the LAG option "Admin = Disabled", so I tried to enable them manually. But within few hours, the whole system collapses.
    • schumaku's avatar
      schumaku
      • muRe's avatar
        muRe
        I just want to use the VLAN to isolate the port,s so my devices don't communicate with each other. The LAG configaration I didn't even touch. It is in default mode. I have just created VLAN. And it works perfectly for a couple of hours. Then I even lose the connection to the trunk port. Do I have to change anything in LAG configaration?
        Thanks
ProSupport for Business
