muRe
Oct 19, 2021Aspirant
GS108TV3 getting automatically disconnected
I have bought two netgear GS108TV3 Switch. First some of LAG changes to Admin-Disable, and I manually change them. But then both of them losing connection within few hours. One of them works well wit...
- Oct 20, 2021Operating a LAG wit two or more ports for the switch-switch trunk, and/or operating more LAG for connecting additional devices?
Tell us more about the intended LAG config please.
muRe
I have a follow-up question. How do I edit or delete a post? I made a typo and don't know how to edit it. My 2nd sentence is making no sense. What I meant is, after the installation ports are getting disconnected one by one, and it shows in the LAG option "Admin = Disabled", so I tried to enable them manually. But within few hours, the whole system collapses.
- schumakuOct 20, 2021Guru - Experienced UserOperating a LAG wit two or more ports for the switch-switch trunk, and/or operating more LAG for connecting additional devices?
Tell us more about the intended LAG config please.- muReOct 21, 2021Aspirant
I just want to use the VLAN to isolate the port,s so my devices don't communicate with each other. The LAG configaration I didn't even touch. It is in default mode. I have just created VLAN. And it works perfectly for a couple of hours. Then I even lose the connection to the trunk port. Do I have to change anything in LAG configaration?
Thanks
- schumakuOct 21, 2021Guru - Experienced UserNo need to touch the default (non-configured) LAG.
Show us more details about your VLAN config, the port configuration.
