ShawnSpencer
Aug 24, 2022Aspirant
GS108Tv3 8-Port Gigabit Smart Managed Pro Switch - dropdown in connectivity speed when using zoom
Hi I have a GS108Tv3 8-Port Gigabit Smart Managed Pro Switch When I use zoom the Switch drops down on connectivity speed form 1 GB to 100 mb. The Switch is connected via LAN to the Co...
ShawnSpencer
- Which components are involved?
GS108Tv3
Logitech StreamCam
- Where is the switch placed?
Attached to the iMac with 3 m LAN Cable Kat. 6a
- What device is being used for Zoom and how is it connected?
iMac, OSX 10.14.6
LAN Cable Kat. 6a
- How is the change in switch speed detected? (LED on switch?)
LED on Switch
Web-Interface of the Switch on the Browser - there one sees the speed of every of the 8 ports
Speed test
Thank you for help
CrimpOn
Aug 24, 2022Guru - Experienced User
This is totally a local network issue? (No internet connection? No router? No WiFi?)
Both the iMac and camera are connected to this switch?
This is the camera: https://www.logitech.com/en-us/products/webcams/streamcam.html
