Retired_Member
Aug 17, 2021GS108Tv3 cannot stream video well - settings?
Hi there, In-home video streaming (Nvidia game streaming via Moonlight) works perfectly at high frame rates (1080p/120) through two GS308 unmanaged switches. As soon as I swap either out for a GS...
- Aug 18, 2021
Retired_Member
Welcome to the community!
Given that you just swapped the GS308 with a GS108Tv3 in which the issue started to occur, have you tried disabling STP and IGMP Snooping?
Kindly check page 179 and 200 of the user manual here on how to disable STP and IGMP Snooping, respectively.
Also, could you provide a network topology showing how your devices are connected?
Regards,JeraldM
NETGEAR Community Team
JeraldM
Aug 18, 2021NETGEAR Employee Retired
Retired_Member
JeraldM
