joejoe5
May 06, 2019Guide
GS108Tv3 cannot use local login with internet access
I just purchased a few GS108Tv3 switches and am not liking this web connected stuff. The new v3 has some features that are helpful to me over the v2 but in trying to set it up I discovered you cannot...
- Jul 18, 2019
Firmware Version V7.0.1.20 released a few days ago fixes this issue: GS108Tv3 Firmware and Software Downloads
I updated all my GS108Tv3 and verified. Here are the Release Notes
Tuna
schumaku
May 06, 2019Guru - Experienced User
joejoe5 wrote:
As soon as it's connected to a network with internet access, i'm forced to create a netgear account ...
That's more for the registration I _hope_.
joejoe5 wrote:
...and can't login locally anymore. If I use my netgear account, i can see the device is still set to local but there doesn't seem to be a way to login.
No simple password prompt like this?
If not, they will make a lot of customers unhappy.... IphieChen YeZ Christian_R !
joejoe5
May 06, 2019Guide
I definately agree it's going to make a lot of customers unhappy. It's made me quite unhappy.
When i setup the switch offline for the first time, i see this:
after login, i always get this message
and then the management info:
After configuring the switch and putting it on a network with DHCP and internet access, this is what I see to login:
I had to create the account (I created a dummy account) which has registered/linked the device to this dummy user. If I login, it redirects to a internet URL and once i'm in the switch, I see everyting is still set to local:
I have a bunch more switches to configure and more on order but this is ridiculous. I don't want my switches talking to netgear! there has to be a way around this.
