joejoe5
May 06, 2019Guide
GS108Tv3 cannot use local login with internet access
I just purchased a few GS108Tv3 switches and am not liking this web connected stuff. The new v3 has some features that are helpful to me over the v2 but in trying to set it up I discovered you cannot...
- Jul 18, 2019
Firmware Version V7.0.1.20 released a few days ago fixes this issue: GS108Tv3 Firmware and Software Downloads
I updated all my GS108Tv3 and verified. Here are the Release Notes
Tuna
IphieChen
May 07, 2019NETGEAR Expert
Hi joejoe5
Thanks for supporting NETGEAR Business products. We appreciate your feedback and apologize for the inconvenience.
NETGEAR is trying to offer Remote/Cloud management options for business users to enjoy the simpler configuration and deployment from anywhere using the NETGEAR Insight app through mobile devices or the Insight Cloud Portal in any device with a web browser. The SSO is for the best security updates and optimum level of protection as YeZ mentioned that we can reach to you whenever your devices have critical security issue. Also, you register the device to get full NETGEAR Hardware Warranty and Support entitlement.
We also understand that most Smart Managed Pro users would prefer the classic local GUI management. Therefore, we kept it as default management mode and only offer NETGEAR Insight management as an optional mode. You could choose not to activate it if you don't need it.
Your opinions about the user's expereiences have been well received. We have been working on improving the user's experience with these new Smart Managed Pro switch with Insight Management capability for a while. Soon we will have firmware update to enable users skip login after the first time they create the account and register the product with NETGEAR.
schumaku
May 07, 2019Guru - Experienced User
The optional SSO to the device(s) would be very useful if it's extended to the Insight Pro roles model. This would allow to overcome the "root" (here: admin) problem with it's shared password for the individual device level operations and management.
