joejoe5
May 06, 2019Guide
GS108Tv3 cannot use local login with internet access
I just purchased a few GS108Tv3 switches and am not liking this web connected stuff. The new v3 has some features that are helpful to me over the v2 but in trying to set it up I discovered you cannot...
- Jul 18, 2019
Firmware Version V7.0.1.20 released a few days ago fixes this issue: GS108Tv3 Firmware and Software Downloads
I updated all my GS108Tv3 and verified. Here are the Release Notes
Tuna
IphieChen
May 06, 2019NETGEAR Expert
Hi joejoe5
Thanks for supporting NETGEAR Business products. We appreciate your feedback and apologize for the inconvenience.
NETGEAR is trying to offer Remote/Cloud management options for business users to enjoy the simpler configuration and deployment from anywhere using the NETGEAR Insight app through mobile devices or the Insight Cloud Portal in any device with a web browser. The SSO is for the best security updates and optimum level of protection as YeZ mentioned that we can reach to you whenever your devices have critical security issue. Also, you register the device to get full NETGEAR Hardware Warranty and Support entitlement.
We also understand that most Smart Managed Pro users would prefer the classic local GUI management. Therefore, we kept it as default management mode and only offer NETGEAR Insight management as an optional mode. You could choose not to activate it if you don't need it.
Your opinions about the user's expereiences have been well received. We have been working on improving the user's experience with these new Smart Managed Pro switch with Insight Management capability for a while. Soon we will have firmware update to enable users skip login after the first time they create the account and register the product with NETGEAR.
SimonCanine
May 23, 2019Guide
I have this problem with my GS110TPv3
Please advise when the firmware with this disasterous mis-design of the login will be fixed, as I have all Netgear purchases on hold while I evaluate alternate vendors.
- SimonCanineMay 23, 2019Guide
Thinking a bit further - how did a design disaster like this ever make it past both the design and marketing team? Someone needs to start paying attention to customer feedback before dropping a new product on the users, especially when such major interface changes are made to a "version upgrade".
- SimonCanineMay 24, 2019Guide
Referring to the "v3" verson - GS110TPv3.
Is this login procedure a security hole?
I manage the network at a private club. We have all of our hardware secured, but members have wireless access to our network. The intent is to allow internet access, but not allow management access to connected devices including the GS110TPv3.
Suppose someone enters the IP of the router and creates a Netgear account. Since they are on the network with our router, will that person then be able to use their Netgear account to login to the switch?
- schumakuMay 24, 2019Guru - Experienced User
SimonCanine wrote:Is this login procedure a security hole?
No, of course not. Similar to changing the admin password on a new device, you have to take ownership of the switch by registering it with Netgear.
SimonCanine wrote:Suppose someone enters the IP of the router and creates a Netgear account. Since they are on the network with our router, will that person then be able to use their Netgear account to login to the switch?
Do you connect the switches to the club network without being ever configured - without the admin password changed? Of course only the device owner can login to that switch, not everyone with a Netgear account.
I'm somewhat amazed that - being keen on security and using Smart Managed Pro switches - that you seem to be using the same IP subnet and VLAN for the device administration as your customers are using to access the Internet. There should be bigger construction zones than these v3 switches.
While talking, what Netgear does is very similar to what Microsoft does offer to non-Active Directory owners allowing to use the Microsoft account for your Windows login. Can I login with my Microsoft account to your Windows system?
