joejoe5
May 06, 2019Guide
GS108Tv3 cannot use local login with internet access
I just purchased a few GS108Tv3 switches and am not liking this web connected stuff. The new v3 has some features that are helpful to me over the v2 but in trying to set it up I discovered you cannot...
- Jul 18, 2019
Firmware Version V7.0.1.20 released a few days ago fixes this issue: GS108Tv3 Firmware and Software Downloads
I updated all my GS108Tv3 and verified. Here are the Release Notes
Tuna
schumaku
Jul 15, 2019Guru - Experienced User
proj964 wrote:i just installed a new gs108tv3. the firmware is the latest (initial). This problem still exists two months after it was first noted in this topic. Does anyone at Netgear have a ETA for a fix? As noted before, it is really hard to understand how this login change ever got into the field in the first place; and why it is taking to long to fix.
YeZ please.
tuna_ertemalp
Jul 18, 2019Luminary
Tuna
- proj964Jul 18, 2019Guide
Thanks for the update. I can also verify that the new firmware resolves this problem.
Jon
