perdurabo
Dec 09, 2019Aspirant
GS110EMX - LAG on 10G ports
Hi! I'm planning to get an Asustor AS5304T NAS which supports LAG on two 2,5G ports so I'm asking myself if the GS110EMX supports link aggregation on the 10G ports as well. If this is the case I hope...
- Dec 09, 2019
Yes, it does!
schumaku
Dec 09, 2019Guru - Experienced User
Yes, it does!
- perduraboDec 12, 2019Aspirant
Thanks for the quick reply, that's great. I'm also considering the Nighthawk SX10 and I'm wondering if it lacks any features the GS110 has to offer (or vice versa) - unfortunately it's not possible to compare the two models directly on the Netgear site.
- schumakuDec 12, 2019Guru - Experienced User
Both the GS110EMX and the SX10 (aka. GS810EMX!) are built on the same hardware platform. By rule of thumb, the features are very similar - the SX10 has a more fancy (less switch tech style) Web UI, which can be operated on a mobile browser easier than the "big" switch UI, the design priorities are set on different aspects. Further on, it comes with some Port Priority (QoS) presets. Very few niche GS110EMX features might be not available on the SX10. Few oddities only, like the On/Off "switch" for configuring Static LAG (Off) or Dynamic/LACP LAG (On) in the UI - appears the UI designer did not wanted to know about radio buttons 8-). This is it - the fancy enclosure design does make most of the differences.
- perduraboDec 16, 2019Aspirant
Thanks again for the feedback! I decided to order the GS110EMX!
