VinceDucat
Feb 27, 2022Tutor
GS110EMX manual step up speed for port 9 and 10 error
hello on the GS110EMX last firmware when i try to fix the speed of those port (9 and 10) trought the GUI. the menu only propose 10Mb 100Mb 1000Mb but those port are 2.5G 5G 10G... is it a bug
schumaku
Feb 27, 2022Guru - Experienced User
For Ethernet link speed above 1000M, link negotitation is mandatory. Thus it's intentional.
Why do you think you need to fix the link rate?
- VinceDucatFeb 27, 2022Tutor
Hell il would like to force at 2.5G beacause i have a problème with wax206 ans gs110EMX some time the connexion beetween wax206 and the network was lost : my solution was to unplugged wire between wax206 and gs110amx and replugge and the connexion came back.. so perhaps a porbleme of autonégociation...
- schumakuFeb 27, 2022Guru - Experienced User
RaghuHR can Netgear look into this possible interop issue with the WAX206 and the GS110EMX please?
- VinceDucatFeb 28, 2022Tutor
WAX206 is used as AP and connect to the GS100EMX via WAN/LAN port (yellow)
