VinceDucat
Feb 27, 2022Tutor
GS110EMX manual step up speed for port 9 and 10 error
hello on the GS110EMX last firmware when i try to fix the speed of those port (9 and 10) trought the GUI. the menu only propose 10Mb 100Mb 1000Mb but those port are 2.5G 5G 10G... is it a bug
schumaku
Feb 27, 2022Guru - Experienced User
For Ethernet link speed above 1000M, link negotitation is mandatory. Thus it's intentional.
Why do you think you need to fix the link rate?
VinceDucat
Feb 27, 2022Tutor
Hell il would like to force at 2.5G beacause i have a problème with wax206 ans gs110EMX some time the connexion beetween wax206 and the network was lost : my solution was to unplugged wire between wax206 and gs110amx and replugge and the connexion came back.. so perhaps a porbleme of autonégociation...
- schumakuFeb 27, 2022Guru - Experienced User
RaghuHR can Netgear look into this possible interop issue with the WAX206 and the GS110EMX please?
- VinceDucatFeb 28, 2022Tutor
WAX206 is used as AP and connect to the GS100EMX via WAN/LAN port (yellow)
- VinceDucatMar 12, 2022Tutor
Is any answer to this probleme ?
