slv_slv
Jun 21, 2017Aspirant
GS110TP bricked - help needed
Hello I tryed to upgrade firmware of my gs110TP from 5.0.5.7 to latest at the moment 5.4.2.30. I downoloaded 5.4.2.30 using TFTP as image2, activated it and rebooted switch After reboot I can't...
- Jun 21, 2017
Hello
Power off and power on solved my problem.
slv_slv
Hello
JohnC_V
Jun 22, 2017NETGEAR Employee Retired
Hi slv_slv,
Welcome to the community!
Thank you for sharing this on the community! Sometimes rebooting the switch resolves the issue. But take note that we cannot reboot the switch while it is on progress of doing an upgrade.
