slv_slv
Jun 21, 2017Aspirant
GS110TP bricked - help needed
Hello I tryed to upgrade firmware of my gs110TP from 5.0.5.7 to latest at the moment 5.4.2.30. I downoloaded 5.4.2.30 using TFTP as image2, activated it and rebooted switch After reboot I can't...
- Jun 21, 2017
Hello
Power off and power on solved my problem.
genek500
Mar 22, 2024Aspirant
Hi,
I have very similar situations, but after restart my switch doesn't work.
Do you know how upgrade this device via Console port?
- schumakuMar 22, 2024Guru - Experienced User
Cold boot does not regain operations?
Officially, Netgear does not support using the (existing) serial port - in the box, on the PCB. Have an eye here in case you are willing (or need) to go this way, instead of sending the switch to service or replacement.
Many Netgear switch models are coming with a limited life time warranty (so some conditions apply - time in years since a product is EoL, first owner, proof of purchase, registration). Start this here on https://my.netgear.com select your switch from the list of registered products, and click on [Request Hardware Support].
FMI: LIMITED HARDWARE WARRANTY
