mvduin
Feb 27, 2023Guide
GS110TP firmware version
I'm setting up a GS110TP that hasn't been used in a while so the first thing I did was to check if it was running the latest firmware, but now I'm quite confused... The support page claims the latest...
schumaku
Feb 28, 2023Guru - Experienced User
That's an interesting one. Attached the release notes GS110TP & GS108Tv2 Firmware Version 5.0.2.22 from my local archive. Would be great, if a Netgear rep could figure out what was going on DaneA JohnC_V Marc_V JeraldM NiveditaP please.
Please refer to the following documents before upgrading your firmware. It is very important to follow the upgrade process documented due to changes in firmware and boot code.
- SCC 1.1 release notes
- Upgrading GS108Tv2 and GS110TP from 5.0.1.x to 5.0.2.x
Bug Fixes:
- Fix the problem that unplugging and plugging the cable continuously with RSTP enabled could cause the switch to reboot.
- Fix the problem that packet always get forwarded to Voice VLAN when its source MAC matches a predefined OUI even when the OUI is deleted.
- Fix the problem that GS110TP PoE Timer (System > PoE > Advanced > Timer Schedule Configuration) does not work past midnight.
- Fix the problem that entries in Memory Log are not showing the correct time zone.
- Fix the problem that when switch receives a Kiss of Death (KOD) packet from the SNTP server, it won't log the event into Memory Log.
- Fix the problem that when Clock Source (System > Management > Time > SNTP Global Configuration) is SNTP, the clock occasionally appears to either running behind or jumping ahead of the real time.
- Fix incorrect description of context help for the "APPLY" button on the Web GUI.
- Change default setting of "Validate IGMP IP Header" (Switching > Multicast > IGMP Snooping > IGMP Snooping Configuration) from Enable to Disable.
- Fix the problem that the device does not retain the configuration of VLAN 2 as the management VLAN after a reboot.
- Fix the problem that backup configuration file shows PoE schedule dates are one month earlier.
- Fix the problem that LLDP-MED is not advertising voice VLAN to IP phones.
Known issues:
- While the link is up, port cannot be removed from a VLAN if it is also member of a LAG.
Workaround: Remove the link or remove the port from the LAG first. - After setting the maximum number of allowed static locked MAC address to zero (under Security > Traffic Control > Port Security > Interface Configuration), no static MAC address can be added even when port security is disabled.
Workaround: Change back the "Max Allowed Statically Locked MAC" from 0 to 20.
Installation Instructions:
- Download using the button below, saving to a convenient place such as your desktop.
- Please follow the instructions provided in Upgrading GS108Tv2 and GS110TP from 5.0.1.x to 5.0.2.x to upgrade the firmware.
This product includes software code developed by third parties, including software code subject to the GNU General Public License ("GPL") or GNU Lesser General Public License ("LGPL"). As applicable, the terms of the GPL and LGPL, and information on obtaining access to the GPL Code and LGPL Code used in this product, are available to you at NETGEAR's Open Source Code Web page. The GPL Code and LGPL Code used in this product is distributed WITHOUT ANY WARRANTY and is subject to the copyrights of one or more authors. For details, see the GPL Code and LGPL Code for this product and the terms of the GPL and LGPL.
Document Type
Downloads > Driver/Software/Firmware
Published 05/14/2011 07:27 AM | Updated 11/30/2011 05:10 AM
- mvduinFeb 28, 2023Guide
If it's safe to do so I'd certainly like to try more recent firmware (e.g. 5.4.2.36) to see if it works any better than the 5.0.2.22 it's running right now... I've noticed that VLAN management via SNMP is very buggy in this release.
I'm working on a project that needs to do VLAN management via SNMP (to setup temporary isolated networks for automated tests) and along the way I've already encountered plenty of SNMP bugs in the main switch we're using for this (a GS748Tv5 running fw 6.3.1.43), but its issues are pretty minor compared to how broken things are on the GS110TP with fw 5.0.2.22.
- schumakuFeb 28, 2023Guru - Experienced User
mvduin wrote:
...I'd certainly like to try more recent firmware (e.g. 5.4.2.36) to see if it works any better than the 5.0.2.22 it's running right now...
Different hardware versions from what I can understand.
Not a very informative bug or problem report either way. Well possible one is entering some grey zone with the probably less teste SNMP config controls.
schumaku wrote:
mvduin wrote:...I'd certainly like to try more recent firmware (e.g. 5.4.2.36) to see if it works any better than the 5.0.2.22 it's running right now...
Well that's exactly what I'm trying to get clarification about here. Either
- is this device a GS110TPv1 and if so why did it ship with 5.0.2.22 even though the website claims 5.0.1.10 is the latest firmware for the v1 and what is the recommended firmware in this situation, or
- is this device a GS110TPv2 and there's just no way to tell other than by guessing based on the fact it shipped with firmware that's only associated with the v2.
If it's actually a v2 then 5.4.2.36 is the official latest firmware for it.
schumaku wrote:
mvduin wrote:I'm working on a project that needs to do VLAN management via SNMP (to setup temporary isolated networks for automated tests) and along the way I've already encountered plenty of SNMP bugs in the main switch we're using for this (a GS748Tv5 running fw 6.3.1.43), but its issues are pretty minor compared to how broken things are on the GS110TP with fw 5.0.2.22.
Well, this thread isn't a bug report, it's a request to clarify what hardware version this switch is and what firmware I can/should run on it. It doesn't seem very useful to give a detailed bug report for an obsolete firmware version anyway. (Also, I've previously done detailed/specific bug reports on this forum and my impression it's a waste of my time since nothing will be done with the information I provide anyway.)
- mvduinMar 15, 2023Guide
mvduin wrote:If it's safe to do so I'd certainly like to try more recent firmware (e.g. 5.4.2.36) to see if it works any better than the 5.0.2.22 it's running right now... I've noticed that VLAN management via SNMP is very buggy in this release.
Just an addendum to note that I did end up installing firmware 5.4.2.36 without any problems, although SNMP doesn't seem to have improved.
(We also bought a new GS108Tv3 switch to evaluate which, on its latest firmware (v7.0.9.11), turned out to have the most horribly broken SNMP implementation of any Netgear switch I've worked with so far... *sigh*)
- ReneDMar 18, 2023NETGEAR Moderator
Hello mvduin,
And welcome to the NETGEAR Community! 🙂As for your inquiry, it seems you are using a GS110TPv2 since the firmware list you mentioned is available for the V2. It will be best to create a support ticket to Netgear team so they can fully verify the version of your switch since Netgear community do not allow confidential information like serial number and MAC address of your device for us to check here. We always suggest to use the latest firmware for your device and if there is a certain issue on some features that is not working correctly, the support can assist to open an Engineering ticket to address that particular issue you are having.
Have a nice day,
Rene D
Netgear Team
