Snaty
Aug 02, 2021Aspirant
GS110TP Hardware Version?
How can I find out which hardware version my switches are (1, 2 or 3)? Nothing to indicate it on the hardware itself or interface. I know it must be either 2 or 3, because the latest firmware for...
Snaty
System Object ID 1.3.6.1.4.1.4526.100.4.19
Model Name Boot Version Software Version
GS110TP B5.1.0.2 5.4.2.18
DaneA
Aug 02, 2021NETGEAR Employee Retired
Welcome to the community! :)
Based from the firmware version you have indicated which is 5.4.2.18, the model of your switch is GS110TPv2. As reference, check the list of the firmware versions for the GS110TPv2 here.
DaneA
NETGEAR Community Team
- SnatyAug 02, 2021Aspirant
Thanks, I'll give the v2 firmware a shot.
It's fiercely annoying when manufacturers don't bother to put the hardware revision somewhere on their devices, leaving it to guesswork :(
