clockworkorange's avatar
Jul 09, 2025
GS110TP hardware version?
Hello, I have the GS110TP V1H1 switch (I'm assuming I have the V1 hardware?).
I am trying to find the correct firmware to use.
When I check the support page for the GS110TP, it lists firmware as 5.0.1.10 (Located here  GS110TP Page)
I noticed something weird.. On the back of the switch, there is a sticker that shows the firmware being newer than what's on the GS110TP page?:
HW: GS110TP
SW: 5.0.3.5
Does anyone know how I can confirm which firmware I should be using, and where I can find the most current firmware?
Thanks.
  • schumaku's avatar
    schumaku
    Would not worry to much, year it's confusing. According to the version number thus appears to be slightly newer from manufacturing back in about the year 2012, while it's indeed a V1 model (with the initial hardware H1).
  • I just found it weird that it shows a higher firmware on the switch vs site..
    Thanks for the input folks.
ProSupport for Business
