clockworkorange
Jul 09, 2025Aspirant
GS110TP hardware version?
Hello, I have the GS110TP V1H1 switch (I'm assuming I have the V1 hardware?). I am trying to find the correct firmware to use. When I check the support page for the GS110TP, it lists firmware a...
schumaku
Jul 10, 2025Guru - Experienced User
Would not worry to much, year it's confusing. According to the version number thus appears to be slightly newer from manufacturing back in about the year 2012, while it's indeed a V1 model (with the initial hardware H1).
