msauer
Aug 02, 2017Aspirant
GS110TP Log contains Failed to communicate with PoE chip
Hundreds or more in log file showing <12> Aug 02 10:56:42 10.2.14.12-1 POE[2187842876]: hpc_poe_brcm.c(803) 2060813 %% Failed to communicate with PoE chip Web search didn't reveal anything. What is...
- Aug 08, 2017
This switch does not provide POE. I contacted the support, they had me update firmware, look at the lights, then offered a replacement, with proof of purchase. I sent it in and waiting for the replacement.
JohnC_V
Aug 03, 2017NETGEAR Employee Retired
Hi msauer,
It seems that it pertains to a POE device connected to the switch. May I know if you do have any POE devices connected to it? Is it still providing power?
msauer
Aug 03, 2017Aspirant
Well, no power at all, will RMA it. Nice to have lifetime warranty on these. Love it.
- JohnC_VAug 03, 2017NETGEAR Employee Retired
Then that answers the question. Please feel free to create a chat / case online on NETGEAR support also be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
- JohnC_VAug 08, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread if you were to set a replacement for your faulty device.
- msauerAug 08, 2017Aspirant
