msauer
Aug 02, 2017Aspirant
GS110TP Log contains Failed to communicate with PoE chip
Hundreds or more in log file showing <12> Aug 02 10:56:42 10.2.14.12-1 POE[2187842876]: hpc_poe_brcm.c(803) 2060813 %% Failed to communicate with PoE chip Web search didn't reveal anything. What is...
- Aug 08, 2017
This switch does not provide POE. I contacted the support, they had me update firmware, look at the lights, then offered a replacement, with proof of purchase. I sent it in and waiting for the replacement.
JohnC_V
Aug 08, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread if you were to set a replacement for your faulty device.
msauer
Aug 08, 2017Aspirant
