Nicolas68480
Feb 18, 2021Aspirant
GS110TPP already registered and Support is responsive !
Hi, I bought a GS110TPP from amazon. I'm unable to logon and register as it states that the switch is already registered to another email (seems that it was a 2nd hand from Amazon...). I opened a t...
- Feb 21, 2021
I got an update from the NETGEAR Customer Care Team that your support ticket has been taken care of and it is already on closed status.
If you do not have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution.” The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Nicolas68480
Thanks DaneA,
case # is : 44179831
Yes I have provided the documents.... I just can't understand that it takes so long to unregister a device....
And I'm really sad to see that cloud is mandatory !
DaneA
Feb 21, 2021NETGEAR Employee Retired
DaneA
- Nicolas68480Feb 22, 2021Aspirant
Hi,
thanks for your help and follow-up, yes finally my ticket was successfully resolved ! I can login to my switch and also manage it locally.
Best Regards,
Nicolas.
