jeroenvg's avatar
jeroenvg
Follower
May 10, 2021
GS110TPv3 POE doesn't work any more
Hi all,
My switch is stuck on a firmware update the problem is that my POE is not working any more.
i 've tried to do a hard reset, manually uploaded a firmware in to the device but still have no result.
here you see what i mean.
I hope there is a solution to it.
Kind regards
1 Reply
  • schumaku's avatar
    schumaku
    Can you access the Dual Image controls on the Web UI on this switch on the local device UI?
    There are two firmware images, one is made active. I would assume it's possible to select the other image to be booted.... Wild guess, the "firmware update queue" might be what you see on Insight.
ProSupport for Business
