Retired_Member
Dec 27, 2020GS110TPv3 time schedule still not working after firmware upgrade 7.0.4.8
After upgrading my GS110TPv3 POE switch to the latest firmware release 7.0.4.8 which should fix the "across midnight time schedule bug" It still doen't work when I want to schedule to power down my PO...
schumaku
Dec 27, 2020Guru - Experienced User
Already tried to drop and re-add the schedule?
Retired_Member
Dec 27, 2020Yes, have done that many times. I even tried to find a workaround, unfortunately no configuration will make the "day hop" schedule work.
- DaneAJan 06, 2021NETGEAR Employee Retired
Retired_Member,
Let us try to perform a factory reset on the GS110TPv3 then reconfigure the setting from scratch. Observe if the same problem occurs.
If the same problem occurs, kindly open a support ticket with NETGEAR Support here at anytime for further technical assistance.
DaneA
NETGEAR Community Team
