Retired_Member
Dec 27, 2020GS110TPv3 time schedule still not working after firmware upgrade 7.0.4.8
After upgrading my GS110TPv3 POE switch to the latest firmware release 7.0.4.8 which should fix the "across midnight time schedule bug" It still doen't work when I want to schedule to power down my P...
schumaku
Dec 27, 2020Guru - Experienced User
Already tried to drop and re-add the schedule?
Retired_Member
Dec 27, 2020Yes, have done that many times. I even tried to find a workaround, unfortunately no configuration will make the "day hop" schedule work.
- schumakuDec 27, 2020Guru - Experienced UserTime zone er all is correct for your location?
Reads to me like an issue to be escalated via support to engineering.
