tty0746
Aug 17, 2026Aspirant
GS116EP and Cisco Switch Trunk Issue
I need to pass multiple VLANS between a Cisco C9300 switch and a GS116EP. I've tried two brand new GS116EP switches, so it has to be an issue with the config. C9300 interface config: switchport...
schumaku
Aug 18, 2026Guru - Experienced User
tty0746 wrote:C9300 interface config:
switchport trunk allowed vlan 1,10,20,30,40,50
switchport mode trunk
switchport nonegotiate
The trunk port on the GS116EP (or for the sake of it on any other switch model) is to define all these VLAN 1,10,20,30,40, and 50 as [T]agged - thaths what you hace defined on the C9300 at least. A trunk does essentiually always carry each VLAN in tagged from.
Disabling the Cisco proprietary Dynamic Trunking Protocol (DTP) and Cisco Inter-Switch Link (ISL) - this is what the
switchport nonegotiate does - is key.
tty0746 wrote:GS116EP config:
port 1 is connected to the C9300
vlan 1 is untagged (C9300 native vlan ID)
vlans 10,20,30,40,50 are tagged
PVID is set to 1
If the intention is to operate the VLAN 1 as untagged (like an access port), including VLAN 1 to be trunk allowed is meaningless. But for simplicity it makes sense (so you can connect any computer adapter here without addiotional local configuration.
That far nothing wrong or forgotten about here.
So what is the effective problem you are working on here please?
Have some access ports and/or combined trunk and access ports eg. to connect wireless access points or the like?
- tty0746Aug 18, 2026Aspirant
Hello schumaku,
The GS116EP will provide connectivity for computers, desk phones, etc. The GS116EP has a static IP set, which is reachable when the 9300 interface is in access mode. I need to find the right configuration to allow the 9300 and GS116EP to communicate with each other and pass these VLANs. There's nothing in-between the 9300 and the GS116EP, and it seems that the config on both ends is correct. What can be the issue here? What could possibly be missing?
