OlafDC
Aug 01, 2016Aspirant
Vlan compatibility with Cisco
Hi,
We just purchased 10 x new Netgear switches (All M4100) to add to an existing Cisco infrastructure.
Fairly simple setup with only 6 Valns.
5: Admin, 30: VOIP, 101 : Management, 100: One set of workstaions, 102 : Second set of workstaions, 200: IPTV, 400: Internet, 401 : Wireless Management
All I wanted to achieve was: 2 last ports on every netgear switch= T and has all Vlans. I have Untagged all relevant ports if I want to use them in the appropriate vlan
Vlan 101 is my Managementt Vlan. (Had to configure inter vlan routing to make that work)
I have only turned on three switches so far and all three are not working. They work for a while and than send packets but are not receiving any.
What am I doing wrong?
Do I have to get rid of the original vlan1 on the netgear?
Is there anything I need to config in the STP to make these switches compatible with Cisco (300 and 400 series).
I am using an optical backbone on Cisco and Netgear switches.
Kindest Regards,
Olaf
Hi DaneA,
Thanks for reaching out.
We got this working.
Step 1: Upgrade to the latest firmware.
Step 2: Forget the GUI.
We had some issues relating to old firmware - causing the trunk links to have some incompatibility with how they tag and untag frames between Cisco and Netgear.
After upgrading the firmware we had access to 'switchport mode access' and 'switchport mode trunk' commands fixing the access port and trunking issues.
Thanks Sir,
Olaf
- DaneANETGEAR Employee Retired
Hi OlafDC,
Welcome to the community! :)
Kindly answer the questions below:
a. Have you set PVID=1 on all tagged ports?
b. How is everything connected? Kindly post a screenshot or image of your detailed network setup.
I look forward to your response.
DaneANETGEAR Community Team
Hi OlafDC,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- OlafDCAspirant
Hi DaneA,
Thanks Sir,
Olaf
Hi OlafDC,
I'm glad to know that you have isolated the problem and resolved it. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
