OlafDC
Aug 01, 2016Aspirant
Vlan compatibility with Cisco
Hi, We just purchased 10 x new Netgear switches (All M4100) to add to an existing Cisco infrastructure. Fairly simple setup with only 6 Valns. 5: Admin, 30: VOIP, 101 : Management, 100: One set of...
- Aug 08, 2016
Hi DaneA,
Thanks for reaching out.
We got this working.
Step 1: Upgrade to the latest firmware.
Step 2: Forget the GUI.
We had some issues relating to old firmware - causing the trunk links to have some incompatibility with how they tag and untag frames between Cisco and Netgear.
After upgrading the firmware we had access to 'switchport mode access' and 'switchport mode trunk' commands fixing the access port and trunking issues.
Thanks Sir,
Olaf
DaneA
Aug 07, 2016NETGEAR Employee Retired
Hi OlafDC,
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance. If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
OlafDC
Aug 08, 2016Aspirant
Hi DaneA,
Thanks Sir,
Olaf
- DaneAAug 08, 2016NETGEAR Employee Retired
Hi OlafDC,
I'm glad to know that you have isolated the problem and resolved it. :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
