pcm0
Jan 21, 2019Aspirant
GS116Ev2 and GS105Ev2 speed issues
I have a strange situation that I cannot figure the cause.
I have had a GS116Ev2 switch setup with VLAN tagging and connected to several devices (including downstream GS105Ev2 switches) for a w...
- Jan 27, 2019
Just to close this thread out...
I was finally able to resolve my issue! It seems that the installer didn't do a clean installation of the wall panel and left the connectors "noisy". By going in and cleaning up the work, everything is up. Thanks for the various suggestions!
I do have a switch question, though, but I'll start a different thread as it's unrelated to this...
pcm0
Jan 23, 2019Aspirant
Could it be something else? I've tried to eliminate as many of the variables as I could and this is the only thing I've come up with as the cause.
One other thing I noticed during this experiment was that the original room (Room B) connection doesn't seem to be as clean as I was originally led to believe. I say that because I noticed that when plugging its cable into the 116, I noticed during the speed negotiation that the port LEDs would turn off for 5+ seconds, then on, then off again for 5+ seconds, etc. for a few cycles before stabilizing to a 1Gb connection.
I assume that is the 116 checking for connectivity issues at the link level, right? If so, does this indicate that it encountered errors and was trying to handle them? Or is it possible that the 105 on that line is bad? I don't notice this behavior on any of the other connections...
pcm0
Jan 27, 2019Aspirant
