fastrack1966
Apr 12, 2022Aspirant
GS305E 5 PORT HOME SWITCH "THE PASSWORD IS INVALID"
Trying to access my switch through the browser. Can see it on the screen, firmware is 1.0.0.5. Going to Admin Page I get "Password Is Invalid". Using the default on the base of device, yes its passwo...
fastrack1966
Sorry maybe I should add I am using the Switch Discovery Tool
- fastrack1966Apr 12, 2022Aspirant
Oh Well that was easy.
1) I reset the switch since I could not ping it, though it was working fine. Reset gave it a pingable ip.
2) After reset the password issue appeared
3) A second reset and now I can use the default password then change it.
Anyone seen this before? Reset 1 loses the default password so reset 2 cures it đČ
