Nándor
Jun 28, 2019Follower
GS305E APR table
Hello, I would like to get ARP table from device. It is possibel?
- Jun 28, 2019
No. The Smart Managed Plus switches are built on configurable - not fully manageable - switch cores. Only some basic configuration and status information is available. That makes the almost non-managed price tag possible.
schumaku
Jun 28, 2019Guru - Experienced User
