EricLap
Mar 04, 2025Follower
GS305E no led's light up
So my GS305E worked perfectly but now only the Power led lights up (very dim) and one other LED on port 4. This is when powered up only, no lan cables connected to it. When i connect my cat6 ethernet...
Mar 04, 2025Guru - Experienced User
Possible switch has gone bad.
Try a different power adapter with same volts and amps as on original one. Most common power adapters so you should be able to find something to check this.
